roadster36 | -- 11-05-2020 @ 9:36 PM |
I am gathering the materials to install the soft top in my '33 sedan delivery project. So far none of the vendors are able to supply the rubber seal for the top insert. The sedan delivery opening is quite a bit longer than the sedan. They all have the coupe and sedan but not the sedan delivery. I don't want to buy 2 coupe weatherstrips as has been suggested and end up with 2 joints on the roof. Does anyone know of a dealer that handles bulk weatherstripping ? Thank you for any suggestions.
TomO | -- 11-06-2020 @ 6:54 AM |
Try Metro Moulded parts http://www.metrommp.com/index.cfm?f=part_list_by_type&Type=Roof%20Rail%20Seals Or Steele Rubber Products https://www.steelerubber.com/automotive Tom
trjford8 | -- 11-06-2020 @ 8:18 AM |
Dennis do you need the small round weatherstrip that goes in the center of the metal tack strip? If so, take a look at the round rubber used to hold the screen on a screen door. It appears to be the same diameter and you can buy it in any length you need. I think it is also made in different diameters.
roadster36 | -- 11-06-2020 @ 9:11 AM |
Problem solved. Thank you once again !
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14298 |
