agriffey | -- 11-02-2020 @ 7:27 PM |
I have removed the glove box and the two screws that hold the lock, but the lock will not come out. Do I have to bend something ? I’m kid enough to get the engine out and instal an 8BA and make it work but I’m not man enough to remove the glove box lock!
Jacques1960 | -- 11-04-2020 @ 2:17 PM |
Bending shouldn’t be required, just (calm) manipulation of the movable tongue on the lock if similar to that on earlier models. Mine was a tad fussy when I had to remove the clock from the glove lid for repair.
blarge | -- 11-04-2020 @ 4:52 PM |
I have removed a Mercury glove box lock many times. The best way is to put some lube around the hole and push the button down and gently rotate/tip the lock to remove. Bill Large
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14292 |
