RAK402 | -- 10-30-2020 @ 4:55 PM |
I have a distributor with 68 marked on the keyed end of the shaft and weights. I have another that looks like 11A on the end of the shaft (I have not taken this one apart yet). What do the differing numbers mean?
40 Coupe | -- 10-31-2020 @ 4:40 AM |
The 68 indicates the internal cam and weights are from 1936 design and the 11A indicates the internals are from 1941 design which is slightly improved to allow a couple of degrees more advance at a lower RPM.
RAK402 | -- 10-31-2020 @ 11:19 AM |
Thank you. Would there be any problems installing the 11A distributor on a stock 1940 car?
carcrazy | -- 10-31-2020 @ 12:53 PM |
There are no problems when installing a 1941 Ford distributor on a 1940 Ford engine. The external mounting features of these two years are identical. Only the internal advance mechanisms differ.
RAK402 | -- 10-31-2020 @ 1:40 PM |
Thank you!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14285 |
