budatlitho | -- 10-15-2020 @ 10:59 AM |
Maybe a dumb question, but where should one position a floor jack- front and rear ?
henlinee | -- 10-15-2020 @ 11:25 AM |
I jack on the rear end -- front axel == old fords are tuff use good jack stands if you go under--good stands!!!! tudorbilll
51woodie | -- 10-16-2020 @ 10:31 AM |
There are numerous opinions on this question. I jack my '46 Coupe from the center of the rear axle and the center of the front axle. I put a 3/4 x 4 x 4" piece of plywood on the jack "cradle" so rim doesn't contact the axle or banjo housing and possibly cause a nick.
nelsb01 | -- 10-16-2020 @ 2:18 PM |
And depending on what kind of floor jack you have -- there are rubber pad inserts that you can buy to minimize damage when jacking. I have a Sears ton and half and have replaced the 'cup' with a flat rubber pad (attached to steel).
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14248 |
