37fordguy | -- 10-08-2020 @ 8:22 PM |
Trying to replace the connectors from the shocks, but the bolt portions are frozen and will not come out. Any help guys?
Jacques1960 | -- 10-09-2020 @ 4:28 AM |
Red wrench
37RAGTOPMAN | -- 10-09-2020 @ 7:00 AM |
hi 37shock problems I am assuming you are talking about the shock links, correct ? you can use a small gear puller, I have a small tie rod type puller that works for me, also a heat gun might help with a little PB BLASTER RUST BUSTER, and use a brass drift and hammer, tap lightly on the shaft, at Home depot, $20.00 for a gallon ,a Great BUY these are a tapered shaft, so should release, hope this helps 37Ragtopman This message was edited by 37RAGTOPMAN on 10-9-20 @ 10:15 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14229 |
