MICHV8 | -- 09-20-2020 @ 5:19 AM |
My 32 has a 59AB and the pumps are mounted using 32 engine mounts...so, does a 59AB has a mount hole for the 32 engine mounts or did the previous owner tap the block? Thanks!
carcrazy | -- 09-20-2020 @ 10:44 AM |
You might get the best answer to your question by addressing it to our Flathead Engine Advisor, Joe Abbin. His contact information is in each issue of the V-8 Times.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14175 |
