V8JR | -- 09-13-2020 @ 1:58 PM |
What is the recommended torque for the rear axle nut, securing the rear hub/brake drum to the axle shaft. Also, if you hit the torque but can't insert the cotter pin do you back off or torque to a higher value so the cotter pin can be inserted? Thanks for any info.
kubes40 | -- 09-13-2020 @ 4:28 PM |
200 ft/lbs. Back off to nearest slot. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14161 |
