V8ford1938@gmail.com | -- 08-24-2020 @ 11:35 AM |
I am in the process of restoring a 1938 Ford convertible cabriolet. Can someone tell me the correct length of the stainless steel trim piece that starts at the door and heads to the trunk. When I took them off the car one is longer then the other. Not sure if they are supposed to be this way or not. Thanks, Tom
TomO | -- 08-25-2020 @ 7:46 AM |
I can't answer your question, but it would be easier to get the correct answer if you use the Ford name for your body style. Ford called the cars "Convertible Coupe" (with a rumble seat) and " Convertible Club Coupe" (with a back seat). Both sides should be the same length. Tom
V8ford1938@gmail.com | -- 08-25-2020 @ 8:16 AM |
Thanks for clarifying the correct body style. I have a convertible club coupe.
fordv8j | -- 08-25-2020 @ 1:11 PM |
I just measured the quarter stainless on our 38 convertible coupe; it is 52 3/4''.... the 38 deluxe business coupe is; 67 3/4''....don't know if the club coupe would be same as a conv. coupe or not.....hope this helps....love the 38s...JRP WVa
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14101 |
