silverchief | -- 08-17-2020 @ 1:37 PM |
Going to change the coolant in my 46 for the first time with this car. Present coolant has been in there 4 years. Assume you just drain the old out and pour the new in, but any helpful hints would be appreciated before I get started. Thanks.
nelsb01 | -- 08-17-2020 @ 2:23 PM |
50/50 mix with distilled water and water pump lubricant. Would also take the time to do a back flush to make sure you get the old stuff out.
alanwoodieman | -- 08-17-2020 @ 3:31 PM |
drain the antifreeze out, rinse with water and drain, then fill with cheap white vinegar and run it thru two heat cycles-you will be surprised at what comes out. then flush with baking soda/water , flush again and then add 50/50 mixture with two bottles of water wetter and water pump lube
silverchief | -- 08-17-2020 @ 4:48 PM |
All new to me.! Thanks much.
cliftford | -- 08-17-2020 @ 7:53 PM |
I've always wondered about so-called " water pump lubricant" It seems to me that if it is getting to the rotating shaft and bushing the seal is all ready shot.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14080 |
