rrodriguezsal | -- 08-09-2020 @ 9:38 AM |
Hello from Bogota Colombia. My friend is starting to restore his 1947 SDeluxe, but there is not clear some details. Front looks like 1946 but others looks like 1948. Do you know where is possible found information about it. The VIN number is 799A- 1875589. We really apreciate your comments. PS. I have restored (frane off)3 offroad cars. Thanks
Kens 36 | -- 08-09-2020 @ 9:48 AM |
Per Mac Van Pelt's website, that serial number would be for a 1947 Ford. http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm Ken
therunwaybehind | -- 08-09-2020 @ 10:25 AM |
The most obvious differences visually are the 1946 has red stripes in all it's exterior chrome stripes and in the grille. There are some early 1947 that share this. Underneath, the shock absorbers are tubes on a late 1947 and 1948s. There is also a antiroll bar or track bar on the front of a 1948. The hubcaps are block letter and blue paint on a 1948 and red stripes and script letters on a 1946. There is a script Ford text in an oval in the middle of a 1946 rear bumper. Differences in heaters are not so year specific. Hood ornament or no and what it looks like, a bird or a streamlined locomotive with smoke is another difference with variations along the way. Las diferencias más obvias visualmente son que la 1946 tiene rayas rojas en todas sus rayas cromadas exteriores y en la rejilla. Hay algunos principios de 1947 que comparten esto. Debajo, los amortiguadores son tubos a finales de 1947 y 1948. También hay una barra antiroll o barra de orugas en la parte delantera de un 1948. Los tapacubos son letra de bloque y pintura azul en un 1948 y rayas rojas y letras de guión en un 1946. Hay un texto Ford de guión en un óvalo en medio de un parachoques trasero de 1946. Las diferencias en los calentadores no son tan específicas de un año. El adorno de la capucha o no y lo que parece, un pájaro o una locomotora aerodinámica con humo es otra diferencia con variaciones en el camino. Die mees ooglopende verskille visueel is die 1946 het rooi strepe in al is dit buite Chrome strepe en in die sierrooster. Daar is 'n paar vroeë 1947 wat dit deel. Onder, die skok skokbrekers is buise op 'n laat 1947 en 1948s. Daar is ook 'n antiroll bar of Track bar aan die voorkant van 'n 1948. Die hubcaps is blok letter en blou verf op 'n 1948 en rooi strepe en Script letters op 'n 1946. Daar is 'n Script Ford teks in 'n ovaal in die middel van 'n 1946 agter buffer. Verskille in verwarmers is nie so jaar spesifiek. Hood ornament of Nee en hoe dit lyk, 'n voël of 'n vaartbelynde lokomotief met rook is nog 'n verskil met variasies langs die pad.
trjford8 | -- 08-09-2020 @ 12:00 PM |
The early '47 cars used parts from 1946, so they look like '46 models. Your friend should purchase the V-8 Club's 1941-1948 book as it has a lot of information that your friend can use. The book can be purchased on the front page of this website by going to the "online store".
rrodriguezsal | -- 08-09-2020 @ 3:16 PM |
Thank you very much
rrodriguezsal | -- 08-09-2020 @ 3:29 PM |
Thank you very much
rrodriguezsal | -- 08-09-2020 @ 3:30 PM |
Thank you very much
rrodriguezsal | -- 08-09-2020 @ 4:06 PM |
Thanks. I have already bougth the 1941 - 1948 on the Online Store. Shipping to Florida to a maul box services and then it will be forwarded to Bogota. Thanks.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14055 |
