V8JR | -- 08-05-2020 @ 11:20 AM |
What is the best way to check the Generator output on a 1953 Ford. Appreciate any suggestions.
TomO | -- 08-05-2020 @ 2:51 PM |
Connect a volt meter to the BAT post on the regulator and then increase engine rpms to about 1,500. The meter should read 7,2-7.4 volts. A meter with a needle is the best type to use for this reading. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14046 |
