hardtop25 | -- 07-22-2020 @ 7:00 PM |
I'd like to remove my column drop from one steering tube then mount it on another. Is soaking, drilling, easy-out the only way to separate the pieces? Thanks.
40 Coupe | -- 07-23-2020 @ 3:52 AM |
Yes. just one headless bolt and make sure the lock bolt inside the drop is retracted (unlocked)
JM | -- 07-25-2020 @ 4:52 AM |
I don't care to use an easy out on that one headless bolt that clamps the drop to the column tube. I prefer drilling a series of small holes across the center of that headless bolt to form a flat blade screwdriver slot. Then use a hand held impact driver fitted with a flat blade screwdriver bit, and impact that bolt to start it moving out in a counter clockwise direction. Then just finish backing it out with a hand held screwdriver. Once that bolt is out, I use a small wedge to open the collar on the drop enough to slide the drop off the column tube. This method has never failed to work for me. John
hardtop25 | -- 07-25-2020 @ 12:04 PM |
Thanks John. Does the headless bolt, now with flat blade slot, then thread back in to clamp unto replacement tube?
3w2 | -- 07-26-2020 @ 6:41 PM |
Why not replace it with an original bolt with a twist-off head? They are available for suppliers like Third Gen Automotive (Michael Driskell).
JM | -- 07-27-2020 @ 6:46 PM |
Hardtop25, if I do a neat job of making the slot in the head of that bolt, yes, I reuse them. This prevents me, or the next owner from having to cut another slot in a breakoff bolt. My cars are all drivers, I could care less about looking 100% correct. Also, that slot is not readily visible unless you're crawling on the floor under the steering column and decide to look up. John
hardtop25 | -- 07-28-2020 @ 6:08 PM |
Thanks all! I think I got this. Yep, my '36 Pickup will be driver all the way.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=14012 |
