JohnA | -- 07-09-2020 @ 6:05 PM |
I'm thinking my starter is stuck on my 239 flathead, just wants to wind but not engaging, or disengage, whats the best way to get it unstuck ?? Last time it did that I rocked car and finally freed up. Is that the best way.
Mr Rogers | -- 07-09-2020 @ 6:39 PM |
Do you think it's stuck against the flywheel or you hear it spinning?
MG | -- 07-09-2020 @ 8:03 PM |
Pull the starter motor and repair/replace the Bendix assembly...
JohnA | -- 07-10-2020 @ 7:13 AM |
o.k will pull starter, once temperature drops below 35 degrees, boy shes hot up here in Kingston ,Ontario, Canada.
kubes40 | -- 07-10-2020 @ 8:56 AM |
MG is correct... replace the starter drive. Mike "Kube" Kubarth
JohnA | -- 07-10-2020 @ 10:38 AM |
Do you think Van Pelt best place for that.?? Johna
cliftford | -- 07-10-2020 @ 11:00 AM |
As good as any, better than most.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13993 |
