tommymdot | -- 06-29-2020 @ 1:35 PM |
Which Ford transmissions from '32 to '48 used the 15 tooth drive gear and the 29-24-18-14 cluster? Thanks
coup | -- 06-29-2020 @ 2:39 PM |
I have one, from a truck.
juergen | -- 06-30-2020 @ 5:50 AM |
They were available in cars and trucks after the war. Cars with 3.54 rear ends were a good fit as well as pickups with a 3.79 and wanting a low first gear.
JM | -- 06-30-2020 @ 9:59 PM |
I buy a lot of '40 to '48 Ford 3sd side shift transmissions to use their gears to upgrade the earlier top load transmissions. in many cases the side load versions have a 29 tooth cluster gear and 15 tooth input gear, which are the gear sets I prefer to use for for this conversion, along with 3.54 ring and pinion gears for the banjo rears. John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13958 |
