ev152 | -- 06-18-2020 @ 12:40 PM |
I am finally getting around to an old project and have always thought it was a 47. This pic is my frame vin number and it's confusing to me. Would you guess this is a 41, or 42, or is it a 47? I pulled this out of a farmers field and am going to resto-mod but need to get a title. My motor and trans will be from a 50 model F1 - 226ci The wheel base is 114" as well. This message was edited by ev152 on 6-18-20 @ 1:25 PM
Kens 36 | -- 06-18-2020 @ 1:05 PM |
Someone may correct me, but I believe that serial number indicates a commercial 6-cylinder from 1946. Ken
nelsb01 | -- 06-18-2020 @ 2:17 PM |
Your vehicle ID is the IGC 30925I I checked Mac Van Pelts serial numbers and according to how it is explained there IG started in 1941 and ran up through 1946 as a 6 cyl vehicle (90 hp) The C stands for commercial. and the 30925I is the production run in the year 1946 (note that I was used for the number 1) Hope this helps. Check out Van Pelts information at http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm Good luck.
ev152 | -- 06-18-2020 @ 2:43 PM |
Perfect - Thanks for the info and link.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13920 |
