36fordor | -- 06-15-2020 @ 11:10 AM |
Stock 35 Ford. When key is turned on two days ago ammeter immediately went all way down, full -. Ammeter came up to abt neutral when started & goes higher around 30 mph or so. Battery had full charge, cranks & starts good. What's going on? Thanks.
cliftford | -- 06-15-2020 @ 7:32 PM |
If you mean that the ammeter goes to full discharge, there must be an intermittent short somewhere or defective ammeter. This message was edited by cliftford on 6-15-20 @ 7:34 PM
TomO | -- 06-17-2020 @ 8:25 AM |
You most likely have a short. Disconnect the wires at the ignition switch and then attach them one at a time to see where the short may be coming from. Tom
Mr Rogers | -- 06-17-2020 @ 10:55 AM |
When is the last time the generator has been overhauled? Brushes sticking? Check Batt connections. Wouldn't a short cause the one fuse to blow?
MG | -- 06-17-2020 @ 11:07 AM |
"two days ago" ??? Does it happen every time?
36fordor | -- 06-26-2020 @ 5:51 AM |
No. In fact could not duplicate this morning June 26. Sorry for late reply.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13911 |
