49acoustic | -- 06-14-2010 @ 9:49 AM |
Is there a particular coolant type that should be used on a standard flathead other than the typical Prestone type of coolant?
TomO | -- 06-14-2010 @ 10:22 AM |
I run with water and a rust inhibitor. In the winter I put in Sierra antifreeze. I prefer Sierra, because it foams less than Prestone and it is less likely to cause serious engine damage if a head gasket leak occurs. Tom
flathead4rd | -- 06-14-2010 @ 6:04 PM |
TomO has the right info. I use Sierra also. The only thing I would add is to use distilled water with your antifreeze. This avoids lime and calcium buildup if the water in your area is hard.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1391 |
