leazer 48 | -- 06-14-2020 @ 7:06 AM |
I need to locate a hood dowel, spring and adjusting nut for my 48 coupe. I have checked the usual sites, C&G, Drake, Carpenter etc. they are either out of stock or don't provide the parts, I will pay for shipping
carcrazy | -- 06-14-2020 @ 10:21 PM |
Wasn't able to locate a hood dowel for you. At least I found a part number from the "green bible", 11A-16929, 7/16"-20 THD. Maybe you can place an ad for it in the "parts wanted section" of this website and someone will have one. This message was edited by carcrazy on 6-14-20 @ 10:23 PM
42wagon | -- 06-15-2020 @ 3:22 AM |
Do you have someone near you with a similar car? If so you could measure the one on that car. Then have someone with a machine shop make one. It should be an easy project for someone with a lathe. Nut and spring should be simple parts to find.
TomO | -- 06-15-2020 @ 6:45 AM |
Try Southside Obsolete in MN or 3rd Generation https://thirdgenauto.com/ http://www.southsideobsolete.com/Southside_Obsolete/Engine_Parts.html Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13906 |
