Gizmo-1001 | -- 06-10-2020 @ 2:10 PM |
1953 Customline in line 6 cylinder water pump rebuild kit or replacement. It seems all the available pumps are for 1954 and later models. Do they fit the 1953 engines?
carcrazy | -- 06-10-2020 @ 10:04 PM |
According to the C&G website they have the water pump for the 1953 Ford 215 cu.in. 6 cylinder engine under part number B2A-8501-A. The 1954 & later 223 cu.in. 6 cylinder engines take part number B6C-8501-CN which they also have. Since two different part numbers are called out, the 1954 part will most likely not fit the 1953 engine.
Gizmo-1001 | -- 06-11-2020 @ 6:27 AM |
Thank you for this info. We will see if we can get the pump now. Thank you for your help!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13899 |
