tweetsmith01 | -- 06-08-2020 @ 8:22 AM |
1940 ford am considering changing to 15 in wheels from the 16in but want to use original hub caps where to find the wheels and what size are they
JayChicago | -- 06-08-2020 @ 9:03 AM |
I have been looking to change the wheels on my new '37 hotrod to something that is not too radical and will accept the '40-48 caps. Check out wheelvintiques.com. I saw a few of their offerings (Series 13,15,21) that say will accept those original hub caps.
juergen | -- 06-08-2020 @ 4:07 PM |
Original 5 1/2 in Ford wheels from late 40s Mercury and really wide ones from Lincoln were what rodders used in the past.
40cpe | -- 06-08-2020 @ 6:28 PM |
I understand Ford pick ups used the "innie" hubcap mounting nubs into the '60s and had the 5 on 5.5" lug pattern.
trjford8 | -- 06-09-2020 @ 8:34 AM |
Ford pickup wheels up to 1965 used the early style hub caps. Use the original Ford wheels if you can and use the 5" wide ones.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13894 |
