Reds34 | -- 06-14-2010 @ 4:35 AM |
What is the approximate weight of a flathead V8? Just engine, no flywheel, with heads and water pumps. Red
carcrazy | -- 06-14-2010 @ 9:06 AM |
The approximate weight of a Ford flathead V-8 (221 to 255 cu. in. versions) as published previously is 550 lbs. That probably includes flywheel and clutch.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1388 |
