Mrbriz | -- 05-24-2020 @ 6:20 AM |
How do you repair an exhaust port that has a hole in it no#1 cylinder. Its leaking water in the exhaust
1931 Flamingo | -- 05-24-2020 @ 6:58 AM |
How big of a crack or "hole"?? Discussion on FordBarn recently about this, water glass recommended by Ronnie Roadster. Paul in CT
Mrbriz | -- 05-24-2020 @ 7:17 AM |
It looks like someone drilled out a broken head bolt and went to deep, went through the side of the exhaust port. Iam thinking of putting a longer helicoil in it with a plug at the bottom This message was edited by Mrbriz on 5-24-20 @ 7:22 AM
37RAGTOPMAN | -- 05-25-2020 @ 7:27 AM |
HI Water in exhaust does the radiator build up pressure,? or water just runs out the exhaust, does the engine have to be running, ? this is not good, for the cylinder, I would drain the cooling system soon as you can to prevent further damage, and see it it can be repaired, hope you make out ok, 37Ragtopman
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13854 |
