MICHV8 | -- 05-12-2020 @ 9:18 AM |
I know United Pacific makes a pre-bent set, but it is very expensive...anybody have a different source?
trjford8 | -- 05-13-2020 @ 1:44 PM |
Finding that tack strip in used condition is I like looking for a needle in the haystack. The problem with a used one is it has probably been bent when it was removed. If UP makes a new one I would step up and spend the money. I look at things from the stand point of how long do I keep looking , how long has the car been apart, and how much time do I have left to enjoy the car. If a tack strip is the last item you need just go for the repo.
51woodie | -- 05-14-2020 @ 8:53 AM |
What are tack strips made of? Can they be made by cutting strips of something like maple or HDPE plastic? Either can be bent to fit a door opening profile. Depending on the amount of bend needed, the maple would have to be steamed, to be bent around sharper curves.
37RAGTOPMAN | -- 05-14-2020 @ 11:55 AM |
MICHV8 need more info on what you are trying to do,? what exactly is the tack strip for, the roof ? is this a metal strip that is split and, that you fold over after you get it tacked down ??? MODEL A sedans used this on the front and rear when putting a top on, oak can be steamed and bent very easily ,gets soft, if this is what you are taking about ? you might have to make a jig to hold in bent shape, I made up some bows for a MODEL T top years ago hope this helps, 37Ragtopman Maine,,, This message was edited by 37RAGTOPMAN on 5-15-20 @ 5:30 AM
1931 Flamingo | -- 05-14-2020 @ 12:07 PM |
Mac's and probably some of the Vendors have tack strips for Model A's, with some work several could be "modified". I've read where others use a plastic type insert. You could try a local upholstery shop that does convertible tops or try a place like Restoration Specalties. (SP). FWIW Paul in CT
3w2 | -- 05-14-2020 @ 2:37 PM |
The original is made of steel and its formed flattened U-shaped cross section does not lend itself to winging it. Some years ago a fellow in California offered the correct shape in a aluminum extrusion for both the '32 version and the different '33-'34 version. He made a very elaborate set of fixtures to bend it without distortion. Unfortunately my reference to him died several computers ago. As for originals, you might find one from a sedan more readily which has the same corner curves and can be shortened to fit a standard coupe.
MICHV8 | -- 05-14-2020 @ 4:13 PM |
Dave Was that the Mitch*ll guy? I tried a number I found and it was disconnected
3w2 | -- 05-14-2020 @ 5:31 PM |
Sorry, I'm not sure.
whygoby | -- 05-18-2020 @ 7:51 PM |
Contact Restorations and Reproductions in Portland. They have a perfect replacement tack trip for 32's.
MICHV8 | -- 05-20-2020 @ 5:36 PM |
whygoby I called them and it turns out we have many mutual friends...thanks for the tip!
whygoby | -- 05-28-2020 @ 9:42 PM |
Mike at Restorations and Reproductions in Portland makes lots of great products for V8's. I'm happy you connected!!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13823 |
