sarahcecelia | -- 05-08-2020 @ 8:25 AM |
Kubes,tom, or any member-any experience with steering box rebuild/ adjustment work??It's got me baffled!! Regards, Steve Lee
37RAGTOPMAN | -- 05-10-2020 @ 7:58 AM |
hi Steve Lee I found Lares has rebuilt steering boxes, call 1 888 577 6964 on the internet, looks like $300.00 or so dollars, might solve your problem hope this helps, 37Ragtopman I think by not replacing both the worm and sector shaft as a matched set is were your problem is, the machining has to be matched perfect, at same angles, I see if one is was worn, what about the other ? did that have no wear ? just a few flat spots is all you need,
sarahcecelia | -- 05-10-2020 @ 9:54 AM |
37RAGTOPMAN' Thanks for that info!I really appreciate it!! I see that Shoebox Ford has the rebuilt steering boxes) for $625, and they need cores, so they give a $150 rebate for your old core; but the info you gave me is cheaper! Bear in mind, I only replaced the sector, because I had to take it down to replace that darn gasket that was leaking!(And it still LEAKS!!), so I thought, why not do it at that time? , and it got me into a BIG MESS!! Thanks again my friend!! Regards, Steve Lee This message was edited by sarahcecelia on 5-10-20 @ 9:58 AM
sarahcecelia | -- 05-10-2020 @ 10:05 AM |
37RAGTOPMAN: I googled and found: Lares Corp., Cleveland St.S, Cambridge, MN. 55008; but the phone is 888-555 0767? Is that the same co. that you talked about? Regards, Steve Lee This message was edited by sarahcecelia on 5-10-20 @ 10:12 AM
37RAGTOPMAN | -- 05-10-2020 @ 10:30 AM |
hi STEVE Lee IT should be 1 888 577 6964 sorry about that, if you get one, make sure you can some kind of warranty hope this helps, 37Ragtopman Maine
sarahcecelia | -- 05-11-2020 @ 5:39 PM |
I googled them (Lares Corp.) and read some complaints that seemed valid. I talked to Chris at Shoebox Central today, He Said the manual does not give the right info to rebuild the steering box, but he has the correct info, and if I send my old unit to him he will have it rebuilt with a new worm and all other new parts needed. Normally it would be an exchange deal, but He is short on cores to rebuild and exchange, so I have to send mine to him for repair. He said that it would be about a one week turn around after he gets mine. That's what I think I'm going to do to solve my steering problems! Regards, Steve Lee This message was edited by sarahcecelia on 5-13-20 @ 4:00 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13813 |
