sarahcecelia | -- 05-07-2020 @ 10:34 AM |
My box was leaking at the sector adj. plate, so while I had it apart to put a new gasket in the sector housing, I installed a new sector. I went step by step in '49,'50,'51'Passenger Car Manual. Everything is set within specs. The sector has about 1/64th play in the mesh; if I make it none, the steering wheel pull goes too much over the spec, and feels tight. Problem:w/the carfront jacked up; when I turn to full L. or R., I have to turn the steering wheel about 10" to get them to start to go straight ahead?? What is causing this "Free play ?" And by the way; the NEW GASKET LEAKS!!Was I supposed to put it in water for a bit first to expand it? (I had to put a wee bit of Permatex on it, to keep it from falling out of the upper sector housing!) Is that chinese junk too???!!! Regards, Steve Lee
37RAGTOPMAN | -- 05-07-2020 @ 10:49 AM |
Was wondering if you adjusted the steering in sequence , first adjust the up and down play in the worm steering shaft, this might have shims for adjustment ? then adjust the end play in the sector shaft, back and forth, they adjust the mesh between the sector shaft and worm what did the gears look like any groves in them ? worm bearings ok, sector bushing's ok, any photo's with the steering wheel in the center, and the steering box in center,you should a little play, maybe 2 inches free play,back and forth let hear how you made out, 37Ragtopman,
sarahcecelia | -- 05-08-2020 @ 8:05 AM |
1)disconnected steering arm from tie rod conection,loosened 3 cap screws on steering box mount and 2 steering column nuts on lower edge/ inst. panel; To relieve any misalignment; re-tightend them all, 2) adj. sector end play, 3)Adjusted worm bearing preload w/ paper shims to book spec., 4) adjusted steering gear worm /roller mesh to book spec., 5) rechecked sector shaft play . This was all done with a Fishing scale, that had a red pointer to read pounds. and a black one that moved with it, and stayed at the highest reading.The manual shows a special scale attached to the steering wheel for taking the readings,; but where would one be able to but one?? Does anybody know the answer to that?? Regards, Steve Lee
sarahcecelia | -- 05-08-2020 @ 8:08 AM |
37Ragtopman-That was a new sector shaft, w/bearing and a new sector gasket.Please read my reply of the seqences just like in the manual. Everything is to BOOK SPECS, and in SEQUENCES as out lined in the manual! The only thing that doesn't make sense is adjusting the sector end play FIRST; because when you adjust the sector /worm mesh later in the sequence, I would think that if you gave it less play ,moving the sector up, makes it tighter against the end play screw on the top of the steering box! That is why the last thing I did was to recheck the end play adjustment screw!! Does any one in the club have any experience with this??I'd like to hear from you!!Tom? Regards, Steve Lee This message was edited by sarahcecelia on 5-9-20 @ 8:05 AM
37RAGTOPMAN | -- 05-08-2020 @ 8:37 AM |
hi Steve Lee how did the WORM on the steering shaft,LOOK ,? it might be worn down, were the teeth from the sector shaft rides,? also how are the bearing on the worm gear shaft, maybe they are bad and that's why you can not get a good mesh,? maybe sloppy , I think there is something simple and over looked ? I think you should have replaced both at the same time, a MATCHED SET, same maker,,, and used USA made parts, did you remove the steering box, and adjusted it on the bench,? might be easier to work and adjust it, I did a few MODEL A boxes and did adjust by feel, no scales, you just have to make sure nothing locks up or gets stiff, as you adjust,the box, 1937RAGTOPMAN,,,,,,,,,,,,,,,,,,,,,,,, hope this helps, LETS HEAR HOW YOU MADE OUT,
TomO | -- 05-08-2020 @ 10:40 AM |
Steve, the sector shaft endplay adjustment is made to keep the roller centered up and down with the worm. The worm and roller mesh adjusts how far into the worm that the roller travels. The worm and roller mesh should not affect the sector shaft endplay. That is why the sequence is important. Center the roller on the worm Bearing preload Sector and worm mesh I cannot see what you have done so I will make a GUESS. The only thing that I think may be your problem is the the sector shaft is meshed with the worm too low. This could prevent the sector housing from seating causing a leak and excessive play. You should go through the assembly procedure again to make sure that the sector shaft is seated correctly in the housing. If that doesn't work, see if you can find a mechanic who still remembers the worm and roller steering system. Tom
sarahcecelia | -- 05-08-2020 @ 12:21 PM |
The Ford repair manual only tells how to "set it all up" while it is in the car. The worm looked okay; but looking at it by eye, you probably won't see wear on the worm unless the is a lot and/or it is uneven. As I previously stated, the omly problem is: at full right or full left, ot takes about 8-10 inches of steering wheel turn to move start the wheels back to the straight ahead position. I took my 1957 Corvette for a ride after adjusting the brakes, and I noticed that it has a little steering wheel play like my '50 Ford does, When the wheels are in a left or right turn, but not as much as the Ford. An old friend, that knows these Fords well,said that is the way they were designed? Regards, Steve Lee This message was edited by sarahcecelia on 5-9-20 @ 8:52 AM
sarahcecelia | -- 05-08-2020 @ 12:40 PM |
Tom, Play in the sector looks, by eye, to be 1/64th" , looking at the end of the sector where that large nut is that holds it on. The steering wheel only goes on it's shaft in ONE position, Right?,and I had it in the STRAIGHT AHEAD POSITION when I installed the new sector ; but I have about 1/4+or so, more turns to the right , than I do to the left?? Do you think that the sector might not centered (midway)on the worm?If so, how could that have happened? Is it possible to install the sector off a tooth or so (on the worm), causing me to have a little more turns one way than the other?? Regards, Steve Lee This message was edited by sarahcecelia on 5-8-20 @ 5:59 PM
JT Ford | -- 05-08-2020 @ 1:50 PM |
I have read in past V8 Times from the modurator on the 49 -51 cars that some of the steering part from china or just as bad as the old worn out ones. And, I have read that SOME of the parts are OK. My two cars could use a rebuild but I think I will just get by with the old ones!
sarahcecelia | -- 05-08-2020 @ 5:56 PM |
Tom, the sector is seated properly, as evidenced by the lower adjustment plate mating to the sector housing WITH NO GAP AT ALL, where they mate up and when the four bolts are tightened! With that being said, why does the NEW GASKET leak at the front right corner? ! (The lowest point of the 4 corners) The cork gasket was a little smaller than the circumference of the recess that it fits in, causing me to put Permatex on 2 small areas of it to keep it from dropping out onto the floor of my garage! Please read my other posts about this problem, that I made today, to see if you have any answers to them. Regards, Steve Lee
sarahcecelia | -- 05-08-2020 @ 6:02 PM |
Tom, I've gone through the proceedure 3 times now, and BY THE BOOK!! still, "NoCigar!!" Look at my reply to Ragtopman. Regards, Steve Lee
1931 Flamingo | -- 05-09-2020 @ 5:59 AM |
Did you get the new sector in the right position (I believe it gets pressed on)?? Are the tie rod ends tight?? 10" way too much. Paul in CT
sarahcecelia | -- 05-09-2020 @ 8:36 AM |
Tom- You are right on your statement about screw that adjusts sector end play! I did it again (the whole scenario) by the book, and it says to do that adjustment. FIRST! Now I got to thinking about it; and realizes that it has nothing to do with the sector moving up or down. Rotating the bottom cover just engages the sector gear into the worm more when moved clock wise, and less when move counter clockwise! It does not move the sector shaft up, or down! Talked to Ray Marler this a. m. ,former Ford mechanic in the '50's; He said the gaskets are junk, and to put silicone on it to stop the leak! Regards, Steve Lee
sarahcecelia | -- 05-09-2020 @ 8:50 AM |
You are right, the stuff that comes from China is real cr*p!! I put a brand new cork gasket in my sector housing, and IT LEAKS!! It was about 1/64th smaller than the recess that it fits in; so I had to put Permatex on ot so it wouldn't fall out when I put the sector housing back on!! If that gasket was sized right, it would fit that recess and stay put!! I spoke with Ray Marler,(He was a Ford mechanic in the early 1950's), this morning about it and he said to put silicone on it so it would not leak gear oil out of the steering box!! Regards, Steve Lee
sarahcecelia | -- 05-09-2020 @ 5:49 PM |
Ray Marler, was a Ford mechanic at 17 years old! He's up in my years now, about 83-84 years of age, I phoned him this morning, and went over the process, and he said I did every thing right!! He also said , some of the parts are from China, and are "JUNK", and to put Silicone Sealer on the leaking gasket!! Regards, Steve Lee
Fhower | -- 05-10-2020 @ 6:50 PM |
h*llo. I am not an expert. but here is what I did. That said is really helpful to have some a help turn the wheel while you are under the car and there is weight on at least one wheel. You look for play at the pitman arm, drag link, tie rod ends and the steering box and steering box bracket. I saw my bracket flexing and replaced the bolts. THEN adjusted the sector gear. What was tight was now loose. I noted that there are opportunities for play throughout the linkage. Sounds like you have the sector gear sorted. Replacing the worm requires a good press and a good block to hold the shaft. I did replace the bearings and races , worm gear, sector gear and shaft. If yours was as mine it was full of cooked gunk. Good luck
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13809 |
