Twrench | -- 04-26-2020 @ 8:23 AM |
Hello everyone, I'm asking what lube should I used in my 60hp 3 speed transmission. 600w oil or 140w gear lube. just wondering. Also would it be the same in the rear end.
juergen | -- 04-27-2020 @ 6:26 AM |
You will get a lot of suggestions with most being useable. Ford did not provide guidance prior to 1949. Their 1949-1951 Shop manual suggests to "Use S.A.E. 80 (S.A.E. 90 in warm climates)" for standard transmissions and to use "Use hypoid or multi-purpose lubricant, S.A.E. 90, for all seasons" for the rear axle. Your V8-60 trans has the same metallurgy/design as the 49 Ford/Mercury trans. This message was edited by juergen on 4-27-20 @ 6:27 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13780 |
