kirkstad | -- 04-23-2020 @ 12:45 PM |
I'm using a volt meter to check the condition of my 6 volt battery,what reading should I get when the battery is at full charge? My volt meter reads 6.25 volts now, should the reading be higher? Thank You. Frank
51woodie | -- 04-23-2020 @ 2:11 PM |
I'm not a battery expert, but from my mechanic days, a fully charged 6V battery ran 6.3 to 6.4 volts. Another test is with a hygrometer, assuming you have a "wet" battery where you can take the caps off and see liquid covering the cell plates. These hygrometers are available at most auto parts stores, and a specific gravity reading of a full charged battery would be 1.238 to 1.258. More important is a load test, which some auto parts stores can do, usually for free. At home, connect your meter to the battery and turn on the headlights. The voltage should stay above 6 volts.
kirkstad | -- 04-23-2020 @ 7:35 PM |
Thank you 51woodie for your help. Frank
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13777 |
