Kairosguy | -- 04-22-2020 @ 12:05 PM |
I've developed a noise in my engine. It gets louder as I depress the clutch. I removed the trans and replaced the clutch and t/o bearing, but the noise remains. I can feel the vibration when I place my hand on the oil drain plug. I think I need to remove the pan to visually check the lower end. Do I need to take off the radiator or drain the block? Is the timing cover a problem?
alanwoodieman | -- 04-22-2020 @ 1:00 PM |
no need to drain radiator, but you will need to disconnect the wishbone and pull down the width of a 2x4 spacer, rotate the engine to have the front throw on connecting rod up--compression stroke for 1 and exhaust stroke for 5, drain oil, remove dipstick tube and take off pan bolts
37RAGTOPMAN | -- 04-22-2020 @ 1:28 PM |
HI 35FORD before you take the engine apart, remove the fan belt so there is nothing revolving that may be causing the problem ? also try when engine running, remove a spark plug wire one at a time, and see if the noise goes away, this may locate were the noise is coming from, maybe a con rod, wrist pin.,ETC how old is the engine,? ever been rebuilt ? diagnois is the key in making a repair, good luck,,, hope this helps 39Ragtopman LET HEAR how you made out,
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13770 |
