begnehm | -- 04-14-2020 @ 2:10 PM |
I am looking for 41 Ford parts for my Special Deluxe Coupe. I need the front center grille, either good used, repo, or any leads to suppliers or repairers. Also, Hood hinge springs Part # 99A16789, Most offer the 91A which is not correct for my model. Any help would be appreciated Brian
efv8CofAAdmin | -- 04-14-2020 @ 4:31 PM |
We do have a Classified Ad section that would be where a request such as this would go. You only need to enter your Wants and the ad should be approved. Web Administrator
TomO | -- 04-15-2020 @ 8:13 AM |
Brian, before you buy new springs for your hood supports, remove the supports from the car and try to close them. If they are easy to move for 1/16" or more, the pivots on the arms are bad. They need to be rebuilt or replaced. This is a more common cause of not holding the hood up than the springs becoming weak. Tom
begnehm | -- 04-15-2020 @ 6:06 PM |
Tom, It is not a case of weak spring, there are no springs to hold the hood up. My problem is that I can't find the source that carried both Part # 99A16789 (Correct) and 91A16789 (not correct). You know, I put it in such a safe place I can't find it when I need it!! Brian
trjford8 | -- 04-16-2020 @ 6:59 AM |
On a '41 you can use the later hinges and springs. The advantage is it allows the hood to open wider and makes it easier to work on things under the hood.
TomO | -- 04-16-2020 @ 7:06 PM |
Bob Drake says he has them in stock Tom
trjford8 | -- 04-19-2020 @ 8:50 AM |
begnehm, you have your private messages turned off. Currently there is a decent repo '41 grille on e-bay. I recall it is $399.
nangeo@verizon.net | -- 04-20-2020 @ 5:38 PM |
I have a real nice hood for sale $350 Call me 9146644050
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13752 |
