acauto | -- 03-23-2020 @ 6:30 AM |
Could someone tell me if this is correct for the left rear fender on a 41 station wagon? Thank You
42wagon | -- 03-23-2020 @ 1:32 PM |
Looking under the car mine is similar except the lower edge comes straight across and is not at an angle with bolt/screw holes along the bottom edge. Keep in mind that mine is a 42 and I believe the 42s have slightly wider wheel base than the 41s. Maybe someone with a 41 wagon will take a look under his car and tell you what he sees.
acauto | -- 03-24-2020 @ 8:59 AM |
Thank You for the reply
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13687 |
