tlm | -- 03-12-2020 @ 6:38 AM |
hi every one in need of a diagram showing where seals ,cups ,orings , go in side master cylinder basically how to put it together
37RAGTOPMAN | -- 03-14-2020 @ 6:46 AM |
TRY using BING.COM type this in, auto brake master cylinder DIAGRAM most master cylinders are made the same,and the way they work, just make sure your PISTON bore has no pits in it. if it does it might hold a good pedal and have bypass problems a shop manual for your specific car would be of great help my 2 cents 1937RAGTOPMAN does that 1950 V8 PILOT have a V8 60 hp flathead engine, like the ones FORD used in the USA, in the years 1937 1938 1939 1940 if you need to have the master re sleeved WHITE POST RESTORATIONS, will install new sleeve and bring back the master to work correctly This message was edited by 37RAGTOPMAN on 3-16-20 @ 3:01 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13661 |
