37RAGTOPMAN | -- 03-09-2020 @ 6:30 AM |
I found this info in a 1947 catalog, which shows 4 different fuel pump push rod, just wanted to forward the information, see PHOTO hope this helps from making mistakes
ken ct. | -- 03-09-2020 @ 1:37 PM |
Also if you change manifolds you m ust also change the baffle tube under the stand between alum. and CI. Theres an inch diff. on them also !!! ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13652 |
