pohair | -- 02-22-2020 @ 12:10 PM |
I'm in the process of completely redoing the brakes on a 41 pickup. I am using the Boling brake setup, but wonder if anyone has used a dual reservoir with the vacuum booster setup. Both pros and cons. Thanks
trjford8 | -- 02-23-2020 @ 1:35 PM |
Did you check with Bolling Bros. ?I'm sure they can tell you. They were at the Turlock Swap Meet and I think they had a dual MC display. If you use a booster you may need a vacuum storage can to operate it.
CharlieStephens | -- 02-23-2020 @ 1:54 PM |
As trjford8 suggested you should start with Boling Brothers but also post your question on HAMB, https://www.jalopyjournal.com/forum/forums/the-hokey-ass-message-board.5/ That forum deals more with the non original parts. Charlie Stephens
pohair | -- 02-24-2020 @ 10:02 AM |
Thanks for the recommendations. I'll contact the Boling Bros.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13624 |
