ross49 | -- 02-07-2020 @ 8:34 AM |
My steering wheel on my 47 Ford is off center when the wheels are straight. Is this adjustment accomplished by adjusting the drag link?
woodiewagon46 | -- 02-07-2020 @ 11:33 AM |
Any good alignment shop can center the steering wheel for you. It's also not too hard to do yourself but several test drives might be required. I did mine and believe it or not the "crown" of the streets will affect it. Yes the drag link is the part you need to adjust.
kubes40 | -- 02-07-2020 @ 11:42 AM |
As has been stated, yes, you can adjust this yourself and yes, do so with the drag link. I'd suggest creeping up on the correct position - perhaps turn the tie rod end one revolution at a time. The crown of the road will effect the centering of the wheel if the front chassis is worn and or the steering gear is worn and / or not adjusted correctly. . Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13588 |
