Kenny's 1940 | -- 01-14-2020 @ 7:12 PM |
I am working on a 1940 Ford Deluxe window regulator. I am trying to replace the window crank gear. I can remove 1 rivet not the other 2. Anyone has any ideas
40 Coupe | -- 01-15-2020 @ 4:39 AM |
Could drill a small hole through the rivet releaving the pressure.
trjford8 | -- 01-15-2020 @ 8:08 AM |
I know you would like to fix the original regulator, but to be honest you would be better of to find a NOS regulator or a good used regulator. There's plenty of them around. Check with Regulator Roy who advertises in the V-8 Times.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13526 |
