replayfun | -- 06-04-2010 @ 1:34 PM |
2 quick questions about my '50 convertible. Where are the bottom of the 2 hood springs attached? Does anyone have a method to install the horn wiring through the steering box and up to thru the steering column. I tried a stiff wire but it keeps hitting against the inside of the steering gear. Thanks for any suggestions.
flathead4rd | -- 06-05-2010 @ 5:57 AM |
Go to shoeboxford.com and get your answer there.
Big Red 51 | -- 06-05-2010 @ 7:35 AM |
The best way to install the horn wire is from the top down then you can twist the wire until it clears thru the hole at the bottom. Don
jfarrell | -- 06-05-2010 @ 7:10 PM |
Just finished replacing the horn wire on a '49. I'm sure there are more than one way to run the wire, but I ran a stiff metal wire up from the bottom to the steering wheel. After the wire reached the steering wheel I taped the new horn wire to the metal wire and pulled it through. It took one try. Jim Farrell
supereal | -- 06-06-2010 @ 10:38 AM |
This tip won't help if you have already pulled to old wire from the shaft. We attach a length of strong plastic fishline to the old wire, and pull it down (or up), then attach the new wire to the line and pull it into place.
replayfun | -- 06-06-2010 @ 10:56 AM |
Thanks Jim, Big Red and everyone who responded. Sounds like I need more patience. I'll try again after I clean the oil puddle on the garage floor and get a better work light. Steve Lillie
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1338 |
