Fhower | -- 11-03-2019 @ 9:22 PM |
I am planning refurbishing the front spring on a 41 Super Deluxe. Plan to remove the spring and disassemble to resurface and lube. I have one clamp that has come loose and need to re-attach. What is the best way to attach? Thanks for any advice
trjford8 | -- 11-04-2019 @ 6:39 AM |
If you look at the other clamp you find that they are riveted to the leaf. I would go to the hardware store and get a rivet of the correct size and length and re-rivet it back on.
Fhower | -- 11-04-2019 @ 6:57 PM |
Thanks!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13362 |
