frank5446 | -- 10-29-2019 @ 12:04 PM |
how do you install this gasket on 39 ford deluxe windshiled
kubes40 | -- 10-30-2019 @ 5:44 AM |
With patience. A lot of patience. Remove the frame from the car. It is imperative that ALL remnants of the old gasket are removed. I lubricate the channel with glass cleaner. Keep it lubricated as you install the new gasket. Start by installing the four corners so to be reasonably certain you have the gasket located correctly around the entire perimeter. Do not stretch the gasket. Again, keep the channel lubricated. Glass cleaner works well as it won't suds up as soaps will. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13350 |
