nubes@bestweb.net | -- 10-26-2019 @ 10:15 AM |
How do I replace the rear shakles on a 1934 Ford pickup?
trjford8 | -- 10-26-2019 @ 1:55 PM |
Do you have the old style shackles? Those are steel sleeved and I drive out the center then put a hacksaw in the middle and split the sleeve to get it out. If you are not concerned with being original I would replace them with the nylon bushing type shackles. Much easier to install. If you replace with the original style you need to use a special tool to drive them in.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13342 |
