rustedorrotting | -- 10-21-2019 @ 8:29 AM |
as some of you know i am trying to get my 41 1/2 ton road ready. i have learned some very hard lessons about fuel. my carb power valve was bad and leaking and end result was about 3 qts of gas in the oil. Now it has a rod knock. Do i have to pull the engine or can i access from underneath? I have the pan loose, but can't seem to get it off.
mfirth | -- 10-21-2019 @ 9:02 AM |
Howdy, even though you have the pan loose, did you try putting fresh oil in it? Have heard of the same problem and fresh oil & filter solved the knock..... Think you have to drop the tie rod to remove pan....others know much more than me. Wish you well, mike
37RAGTOPMAN | -- 10-21-2019 @ 3:23 PM |
hi flathead rod knock I would pull the pan and check the oil pump screen and see if is clogged , how is the oil pressure ? before that,,,, remove one spark plug wire one at a time [while running,] to locate which cylinder is making noise, you can remove that connecting rod cap and check the rod journal for any damage, it also might be a bad timing gear making a tapping noise, clicking noise,? lets hear how you made out, 37 RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13333 |
