stan white | -- 10-15-2019 @ 2:06 PM |
buy a new dropped axel or have yours dropped?? I had my original axel dropped big mistake, kingpin hole diameter distorted .813 dia as large as .837. kingpin dia is .812. { BUY A NEW AXEL!!} Stan This message was edited by stan white on 10-15-19 @ 2:11 PM
trjford8 | -- 10-16-2019 @ 6:24 AM |
Stan, take it back to the guy who dropped it and make him fix it or give you another one. If they messed up the holes who knows if the camber is correct. The other option is to purchase a new one from Magnum Suspension, Pete and Jakes, or Chassis Engineering. On new axles check to make sure they are made in the USA. Lots of Chinese axles out there. Another possibility is to have the axle sleeved to the correct diameter This message was edited by trjford8 on 10-16-19 @ 6:26 AM
CharlieStephens | -- 10-16-2019 @ 6:52 AM |
trjford8 s right about the bad axles. I think I would go to the archives at HAMB and read up on the bad ones. See: https://www.jalopyjournal.com/forum/forums/the-hokey-ass-message-board.5/ Charlie Stephens
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13313 |
