MICHV8 | -- 10-15-2019 @ 12:12 PM |
I have power and ground to the dome light canister, but can't make a dash bulb fit correctly. The positive contact doesn't appear to be spring tensioned (like headlamp bulb sockets)...is there a special bulb or is my dome socket malfunctioning? Thanks!
trjford8 | -- 10-16-2019 @ 6:17 AM |
If it's an old original there is a possibility that the spring has broken. Probably need to take it apart to check. The spring is easy to change.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13312 |
