chiefdave | -- 10-15-2019 @ 6:14 AM |
Does anyone run one of these? I'm going to run one on a 8BA and need to know what coil to run, what to have the advance curve set at and if I need a ballast resistor. This will be with a 6v system, 390cfm Holley on an Offy manifold and Offy heads. Other than these bolt on mods the engine is stock with a .030 over bore. Thanks in advance for the help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13311 |
