tweetsmith01 | -- 09-23-2019 @ 2:59 PM |
how to replace the sway bar ends and studs must i remove the sway bar from the car
trjford8 | -- 09-24-2019 @ 7:17 AM |
If the ends are worn then most likely the rubber bushings on the bar are also worn. Remove the bar and check all the parts for wear. I use a "pickle fork" to separate the parts. This message was edited by trjford8 on 9-24-19 @ 7:18 AM
tweetsmith01 | -- 09-28-2019 @ 4:16 PM |
i have removed the perch pins i wonder how you would install new pins without removing perch pin bolt thanks for your help my 3lb hammer arm is tired
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13252 |
