sarahcecelia | -- 09-23-2019 @ 1:20 PM |
What tire pressure is recommended for 205-75 R15 radials on a 1950ford sedan? Front_? Rear_?
BUCKAWHO | -- 09-23-2019 @ 2:41 PM |
Hi....I run 35 lbs. on my '51 coupe.The tires are old with no build date. Works OK for me. BT
sarahcecelia | -- 09-23-2019 @ 5:25 PM |
35lbs. all around is not right. The front needs more than the rear because of the 6oo + lbs. for the motor starter, battery, radiator, coolant, and so on. 35lbs. in front maybe, and 32lbs. rear? Regards, Steve Lee
MG | -- 09-23-2019 @ 6:11 PM |
I do the same as BUCKAWHO - 35 pounds each tire, all four, for the past 25 years....
Big Red 51 | -- 09-23-2019 @ 7:24 PM |
Ditto MG. '51 F-1, '53 Crestline and '54 Crestline all with lots of highway mileage.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13251 |
