jamesmundstock | -- 09-17-2019 @ 10:48 AM |
Is the worm gear pressed on? If it is, I am seeing the inner column shaft needs removed from the steering box in order to press it off. To do that it looks like the locking collar at the upper end needs removed so the column can pull through the box. Is that a correct assumption? Thanks in advance for the feedback.
trjford8 | -- 09-19-2019 @ 4:37 PM |
The locking collar should be removed. It's only held on with two set screws. This message was edited by trjford8 on 9-19-19 @ 4:42 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13236 |
