MICHV8 | -- 09-16-2019 @ 4:00 PM |
I bought Dennis Carpenter (good guy) deck lid seal (B-7043720) and am wondering if it goes on the trunk lid or the deck frame...neither is a perfect fit by any means. Thanks for the help
3w2 | -- 09-16-2019 @ 5:00 PM |
There was no seal originally for '32 deck lids so there's no correct way to install it. If it is like the '33-'34 lid seals, it fit in the channels in the quarter panels and upper back panel.
MICHV8 | -- 09-17-2019 @ 11:26 AM |
thanks Dave Yep, I have a 34 and the seal inserts into the deck channel, no problem. However, as you well know, the 32 channel is wider at the top of the trunk opening than the sides. So, I'll simply insert the seal into the side channels and call it a day...
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13232 |
