jal9846 | -- 09-09-2019 @ 2:37 PM |
Does anyone have a source for the correct sized fuel pump top gap gaskets for 35-46 fuel pumps? I need the gaskets that go on the metal top caps for both small top and large top pumps. All the aftermarket kits available do not include this gasket. They include the gasket for the glass bowl type, which is too small for the non-bowl type. The gasket I need for large top for example is 2-1/4" OD x 1-7/8" ID for the large top 1937-46 type pumps. The small top earlier pumps...I have found I can use a std. size o-ring, since they are smaller....but I would welcome a source for these also in cork/fiber type.
ken ct. | -- 09-09-2019 @ 5:28 PM |
I have both styles. ken ct. 1-203-260-9780
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13216 |
