tweetsmith01 | -- 09-09-2019 @ 6:04 AM |
in trying to replace upper steering bushing with a flanged bearing like a wheelbarrow bearing how does the bearing fit down the column so the steering wheel will fit do i have to grind the flange off the replacement bushing doesnt have a lip on it?
trjford8 | -- 09-09-2019 @ 6:44 AM |
I believe once you grind the flange off the bearing will come apart. Call C and G parts as they have a bearing retrofit kit that will work with your '40 column. It comes with the bearing, tapered sleeve, and spring. I think the cost is around $20 and well worth it. I have used several of those kits. This kit is actually a kit that was used in the later Ford columns. Check our vendors in the links section on this site This message was edited by trjford8 on 9-9-19 @ 6:52 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13213 |
