kirkstad | -- 09-02-2019 @ 2:09 PM |
The inner and outer brackets on my 36 front bumper are both bolted to the outer side of the frame rail. I have the 35-36 book which doesn't tell if this is correct. I have new bumper grommets I want to install and judging from the openings on them, it seems that the brackets (arms) should mount on each side of the frame rail. I'm I correct? I have't worked on the bumper till now. Thank You Frank
3w2 | -- 09-02-2019 @ 2:18 PM |
You're correct.
kirkstad | -- 09-02-2019 @ 4:32 PM |
Thank You 3w2 for your quick reply.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=13190 |
